Deep cycle batteries are most often found in golf carts. They are usually a 6-volt, not 12 volt. They tend to have thicker plates and can withstand the constant charging/draining better than 12v batteries. You can buy 2 6-volts and wire them in a series (not parallel) to create a 12v system. This will not double your amp hour rating, but it will make them compatible with a 12v backup pump system. Generally, Trojan is one of the better known 6-volt brands. They require maintenance (water). If you want to go the maintenance free route, the best 12v deep cycle battery I know of is the Lifeline AGM made by Concorde. They are very pricey, but generally have thicker plates and are a higher quality battery vs. your cheaper marine options. Their 31T size has an amp hour rating of 105.
I don't mean to question you, but I would be extremely skeptical that you have a true 3/4 HP pump if it takes 45 sec to 1 minute to complete a pump cycle. Unless you have a double float pump switch and/or a pit the size of the Grand Canyon, then your pump rating is overrated IMHO. A Hydromatic VS33 1/3 HP can pump 40 GPM at a 10' head. A good 3/4 HP sewage pump would do around 150 GPM. Is your pump really doing 100+ gallons a cycle? A lifetime warranty won't do much for you if you flood again.
My pump runs for six seconds then is off for 30 seconds during heavy rain or thaws. I'm still surprised that your pumps die so quickly.
