Originally Posted by
carmel corn
Some good advice above. If you are going to use multiple batteries, I would further add that you should:
1. Make sure they are as similar as possible (same amp hour rating, age and don't mix AGM's with wet cells even if they are both 12v).
2. Make sure each one is desulphated individually before hooking them up together.
3. Make sure your charger unit can handle recharging in a series. You would want one with at least a 10 amp charging power.
Also, I would not put much stock in "lifetime" warranties or the horsepower ratings. A true 3/4 HP pump would pump too quickly and cause your pump to short cycle. A good 1/3 (preferred) or max 1/2 HP is all you need. IMHO - the best pumps you can buy are Hydromatics or Zoellers and they do not offer such warranties. If you bought your pump at a big box store (ex. flotec, simer, wayne, etc.), I would reconsider your purchase.
