Results 1 to 6 of 6
Thread: 6" Certainteed Pipe splitting
    Default 6" Certainteed Pipe splitting
    I have made 5 repairs to a 6" water line since October. The line is 6" SCH 40 Certainteed pipe. The line is splitting at various locations. We install a clamp and cover it up. The line feeds a 130 unit apartment complex. The pressure fluctuates from 55 to 75 PSI. Any ideas?
    Dec 2007
    Time to replace the line?
    In the Trades kordts's Avatar
    Oct 2005
    exurban Chicago
    What is this, metal or plastic?
    This is a plastic line. Yes, it may be time to replace however, I am trying to do what I can to avoid that cost for my customer.
    Plumber Cass's Avatar
    He needs to bite the bullet before you have a catastrophic failure.
    Better to have it down when every one is expecting it rather than suddenly when it will be extremely annoying.
    The cost may be even higher if it is done on an emergency basis.
    Dec 2007
    With the repair approach eventually you will get that whole new line. In the end the piecemeal replacement will cost far more than just doing it right the first time.
    What is this clamp you are installing?
