Shluffer
Over the summer I remodeled my bedroom, partly to replace the radiators which blew over a winter. we put in a significant amount of high output baseboard heat. This winter we discovered that the baseboard was sufficient, but that it takes a tremendous amount of oil to heat the room. After some research we figured out that the room is made of cinder block on the outside coated with stucco. On the inside, there are 1 x 2'c to allow the plasterboard to be hung. There is one inch between the outside wall and the plaster. The only insulation is a sheet of moisture barrier. I am trying to figure out if there are any materials that I can insulate with, without tearing the walls down, that will allow me to decrease my heating bull. I'm thinking spray in foam, but would appreciate other ideas. Any thoughts?
