Results 1 to 7 of 7
Thread: Running a pump from a generator
    Default Running a pump from a generator
    I have a 2hp irrigation pump set up for 230v. I want to use it to fill a water truck from a creek to fill stock tanks. Would there be any problems with running it off of a gas powered generator? What should I be concerned about?
    Moderator valveman's Avatar
    Mar 2006
    As long as the generator will start it, then it will run fine. Might start with a 3500 watt, may take a 5,000.
    Like an engineer alternety's Avatar
    Apr 2006
    Washington
    When you start a big electric motor there is a short but large surge. The generator must be rated to handle that surge. The continuous load rating of the motor and generator can be the same, but the generator has to take the surge. This may mean a generator rating larger than otherwise needed for continuous use. Some generators are better about this than others. Check specs.
    DIY Senior Member Mr_Pike's Avatar
    Jun 2007
    Nebraska
    Quote Originally Posted by tmartin View Post
    Isn't a two HP something like 1500 watts?
    We run pumps on generators all the time. Just make sure you have enough generator for the job and grounding protection in place.
    Mar 2006
    1 HP equals 745.7 watts. But start up takes about 6 times that much.
    Default Thanks for the info.
    I believe it is a 6000 watt generator. It has a 230 outlet. It runs an electric jack hammer pretty well. I was trying to save some money by using an electric pump and a generator that I already had, but I think I will just buy a gas powered irrigation pump. I don't think I have room for both the pump and the generator on my truck. I think a two inch pump and a five horse engine should work good enough for filling a water tank. Thanks for all the input.
    Previous member
    Jul 2005
    Riverview, Fl.
    If your looking for a deal on Gas pumps, check out the three I have left on my Specials page: http://www.pumpsandtanks.com/specials.htm
    The 3hp is already sold.
    bob...
