I installed a backup system and used a check valve for each pump and a "Y" to bring them together after the check valves. The directions (yes I read them) tell you to drill a 1/8 inch hole in the backup pump discharge pipe 3 inches above the connection between the backup pump and its discharge pipe to prevent the pump from locking up with suction.
Do I need to drill a similar hole in the discharge pipe from the main pump? When I was testing the system, after the main pump stops pumping water out of the sump it makes this loud gurgling sound for about 10 seconds. Why is this happening?
Thanks...
Thanks...
