I need to move an existing toilet in a high-rise condo with concrete slab, so I can widen the shower and door to 32" min or greater. Cutting the floor is not an option due to significant cost (x-ray floor, structural engineering assesment, Assoc. permission, access to floor from below, etc >$40K)
The problem is really the location and orientation of the toilet. Using the existing flange:
1) can I change the install postion 90 degrees and use a rear outlet toilet create some space and discharge into the existing waste flange
2) create a wall over the flange and install a wall hung toilet that discharges into the existing waste
3) leave the toilet where it is and move the shower (still tied into the existing shower drain using a built up base)
4) any other ideas?
See pdf for a room layout.
JM
4) any other ideas?
JM
