Results 1 to 15 of 17
Thread: Thermal Expansion Tank Location
Hybrid View
    Default Thermal Expansion Tank Location
    I recently had a hot water heater and thermal expansion tank installed by a licensed plumber. I was not present at the install. But afterward I noticed that the thermal expansion tank was installed on the hot water side of the water tank.
    Will the expansion tank still work (reduce water pressure from thermal expansion) when installed on the hot water line? And if so, will it cause any problems having it installed this way?
    Thank you for any advice you can give.
    -Bob
    It will work, but is not per the manufacturer's instructions. Was a permit pulled? Was the plumber licensed? Was it inspected?
    Installing it on the hot side will seriously decrease its life.
    Most inspectors, in the absence of a specific thing in the codes, fall back on the manufacturer's instructions...if it is not per those, the plumber should fix it for no cost, in my unprofessional opinion.
    Default tank
    An expansion tank will work no matter where it is installed in the system. Recommendations call for it to be in the cold water line adjacent to the water heater, and after the shut off valve. These requirements are to insure that the tank does its thing even under unusual conditions. The installation in the hot line can cause premature failure under specific conditions which may never happen in your case.
    Plumber gear junkie's Avatar
    Feb 2008
    Virginia Beach, IPC country
    premature failure will happen. even installed on the cold side, it needs to be 18" away from the the WH. I'd call the guy back up and show him the instructions on how to do the job right and have him do the job right or give you your money back.
    Dec 2007
    Quote Originally Posted by gear junkie View Post
    Huh? http://www.watts.com/pdf/1915356.pdf
    Default tank
    Good luck finding a spot 18" away from the heater to put the tank in this area. There is usually only about 12" from the wall to the heater inlet. I believe you are resorting to hyperbole to make your point. Whether there is premature failure or not depends on a slew of variables, such as the volume of water beneath the diaphragm, the temperature of the water, the presence of heat traps, etc.
    Feb 2008
    Quote Originally Posted by Redwood View Post
    Thanks for the correction, we have a lot of pex here and that needs to be 18" away from the heater(that I'm sure of). I got the 2 mixed up.
