Hello Everyone,
I recently bought a house which had well problems. The former owners had the well hydrofractured just before settlement. They were getting less than 1 GPM before hydrofracing, and I assumed that hydrofracing would provide enough additional capacity. Well, I was wrong, partly. Only when we have company over does the well pump switch trip, and doesn't recover for up to 12 hours. Although we have adequate supply for my fiance and me, she is adament that we have more water available. With a bit of water knowledge (civil engineer), I believe that I have a high static water level (well is 410' deep), with a low yield.
I currently have a goulds 3/4 HP well pump, Wellmate WM-12 pressure tank, and an ecosystems water softener. What I would like to do is add a 300 gallon poly tank with Pumptec protection on the float switch, which would collect water pumped directly from the well. I would then put a Grundfos MQ3-45 constant pressure pump on the outlet of the tank which feeds into my softener. I would like to get rid of my pressure tank, but am leary about how the constant pressure pump will work with the water softener.
I'm having a friend who has a HVAC company do the work, but as he has never put one of these systems in, we were curious as to whether this sounds like a good plan of attack. Thank you in advance for any information anyone can provide.
Tyson
Tyson
