Franner11
hey guys!
fran here again.
a question in regards to a new sink install in my bathroom....
so i bought a new faucet online and it came with the flexible supply lines for both hot and cold.
consequently, the flex lines connect to the faucet itself and on the other end where it would connect to the water supply lines, it's the same 1/2" hex bolt end fitting as the grey pvc supply lines with 1/2" hex bolts, so i bought a couple of male to male brass compression fittings to connect the two.
when i went to lowes to get the brass "nipple" couplings, i talked to the guy in the plumbing department, and he said not to use teflon tape for the threads - that teflon would defeat the purpose of the rubber washers keeping leaks from happening.
so, i connected everything and it's slowly leaking.
my question is - is there any way i can fix the leak, or should i bring eveything back and just get a really long (like 30 inches) flex tubing to connect the faucet directly to the shut off valves?
the grey pvc supply lines running from the shut off valves have a 1/2" connector hex bolt thingy, and i think that's where the leak is happening. either the bolt thingy doesn't have a rubber washer, or the rubber washers have been compromised.
hard to explain without pictures, but i'll attach a couple of the pieces i have so you'll hopefully know what i'm talking about.
i know this is a unique connection situation - normally you just have the flex lines running from the faucet to the shut off valves, but i thought i could work with what i have.
any better way to do this?
fran here again.
