I have diverter valve that is pretty much shot in a house built in '43. The walls are tile, but I have access to the plumbing through a closet.
I would like to replace the whole assembly as the hot and cold water valves leak some and they feel a little sloppy when you turn them. Problem is, the 3 holes in the tile (hot, diverter, and cold valve) are 5 1/2 inches on center for a total spread of 11 inches from hot to cold water valve.
The manifold assembly is joined with 4" brass nipples, where the new ones that I have found are one-piece cast. The holes don't line up on these newer ones as they are closer together.
Does anyone know of a place where I can get the assembly that is not cast as a single unit? I figured that way I could even use the old brass 4" nipples to connect everything. Or does anyone make a larger manifold that would fit the holes in my wall?
