Results 1 to 2 of 2
Thread: Plumbing vent flashing
    Default Plumbing vent flashing
    Not really a remodeling question but thought it fit best here (I am remodeling, though :-) While in my attic, I notice sunlight streaming in by my vent. I then noticed water damage on some boxes stored under the vent. The flashing appears to be rubber (it's black) and ripped. The roof is a very steep pitch. From my attic floor to the penetraction, I'd guess it to be 12 feet. I will probably be replacing the roof in a year or two. Is there a relatively simply patch I can use until I re-roof, or should I just replace the whole flashing piece? Thanks.
    PS 4020 will do the job too bad its going to cost way more then a new boot.
    I would look for Geocell 2300 with some reinforcing fabric, thats a simple fairly low cost way to fix it. If you didn't want to get on the roof you could always fill in around the boot with foam in a can
    Good luck
    Lou
