Quick question: Because of the condition of all of my galvanized hot water pipes, I have decided to totally replumb the house with wirsbo pex. Small ranch, shouldn't be difficult. I am new to pex, but am a good diy. I want to connect directly to the hot water heater. I purchased the water heater fittings, etc... but am wondering if it is ok for a little of the pex to poke through the wall into my garage to connect to the hot water fittings (the metal hose). I know that pex is UV sensitive. Would this be another appropriate place to use a copper stub-out instead? Or should I run copper through the wall into the attic, where I could then tie into the pex? Should I be so concerned about UV in my garage (sometimes I leave the door open...)
Thanks in advance.
Thanks in advance.
