Results 1 to 9 of 9
Thread: Ceiling Fan Wiring
    Default Ceiling Fan Wiring
    I have a SMC fan motor with four wires,by pairing two sets of wires I'm able to run the motor CCW, changing the pairing will run the motor CC.
    I'm wanting to add the capicator to increase the speed.
    Where would the capicator be incerted t odo this
    David D
    DrD
    Jun 2007
    North Carolina
    cap won't increase speed
    Computer Programmer Bill Arden's Avatar
    Sep 2006
    MN, USA
    Some celling fans will run faster if you shorten or flatten the blades.
    Try running it without the blades to see what it's unloaded speed is.
    Important note Ė I donít know man made laws, just laws of physics
    Disclaimer: I'm a big fan of Darwin awards.
    Jun 2007
    North Carolina
    Quote Originally Posted by Bill Arden View Post
    by doing this to gain more speed will the fan move more air or will the air flow be about the same
    In the Trades Bob NH's Avatar
    Oct 2005
    New Hampshire
    The POWER (Watts) required by a fan varies approximately (theoretically) as the third power of the speed. Therefore, increasing the speed by only 10% increases the power requirement by 1.1 cubed = 1.331; or an increase of 33 percent. Since power= Volts x Amps, that means you need 33% more Amps.
    Now resistive heat loss in the windings varies as current squared x resistance. The resistance is approximately constant, (actually increases slightly with temperature), so the heating increases as Amps squared, or 1.33 squared = 1.77. That means that a 10% increase in speed will increase the heating in the windings by 77%.
    If you increase the heating in the windings by 77% you will eventually cause failure of the insulation of the windings. That will produce a short circuit - much sparks and smoke - until it (you hope) trips the circuit breaker.
    Now, you are the one to decide if you really want to increase the speed of the fan motor.
    The capicitors ,1.5 and 3.0 UF were initially in the circuit through a three position switch. I don't know how to wire them back into the circuit.
    David D.
    DrD
    Bob,
    This fan came with a three position pull switch. when I received it the wiring was already dismantled. I can pair the fan wiring to made the fan run CW or CCW.
    I don't know how to wire the capicator in to chane the speed
    DrD
    Oct 2005
    New Hampshire
    Your first post on 3/28 said that you wanted to insert a capacitor to increase the speed.
    My post on 3/30 was in response to that first post. It explained why increasing the speed beyond the maximum speed for which the fan and motor were selected or designed will result in destruction of the motor and could cause a fire.
    If you are simply trying to replace capacitors to restore the fan/motor to an original factory condition, we don't have enough information to give you that answer.
    Jun 2007
    North Carolina
    I do!
    Throw the junk away and buy a new fan.
