Results 1 to 5 of 5
Thread: Kohler Rialto K-3402-PB toilet
    Default Kohler Rialto K-3402-PB toilet
    I have a Kohler Rialto (model # K-3402-PB) toilet and I just replaced the Cap Plunger Kit any how after I replaced it the toilet reservoir fills up but I can still hear water running If I go to the water meter you can still see the water meter running. If I pull up on the float ball a little the water stops running. Any ideas what would be causing this?
    Thanks in advance,
    Ralph
    Dec 2007
    Aren't You Lucky! Looky here!
    http://www.kohlerserviceparts.kohler...ab9457b5cdf966
    Did you know that for a couple of hundred bucks more you could have a nice new Toto Drake... Made by a company that does not rake you over the coals for replacement parts. Plus it will flush a helluva lot better than that dinosaur!
    DIY Member ron in sc's Avatar
    Mar 2005
    South Carolina
    I don't know if your Rialto is the older model that used 3.5 gallons to flush or not but if it is I'd rebuild it. I have a Rialto that I installed in 1988 and I have no complaints. I think it's gotten stopped up less than half a dozen times in 20 years. I did have to rebuild it a few years ago as just about all the internal parts were worn out or corroded.
    I installed a Toto Drake in my detached garage yesterday and it was very simple and easy to install. I also installed a Toto ADA height Ultramax in our new downstairs master bedroom suite that's nearly finished.
    Totos are my choice for replacement but I also like that old Rialto. The other Kolher toliets in the house are old Wellworth Lites that I definately would not recommend.
    If you are going to replace your Rialto I be very interested in acquiring it, if it's the old model.
    Dec 2007
    As always the only thing wrong with the rialto is the cost of parts!
    DIY Member grazzy's Avatar
    Nov 2007
    Virginia
    Cool
    the 1B1X after-market replacement is now available at Lowe's for $9.99.
  1. Kohler Rialto K-3402 toilet fill valve repair
    By koehler in forum Toilet Forum discussions
    Last Post: 04-13-2014, 07:44 AM
  2. Kohler Rialto K-3402 - Flush Ball replacement
    By thediver in forum Toilet Forum discussions
    Last Post: 06-05-2011, 12:11 PM
  3. Replies: 4
    Last Post: 06-30-2010, 02:10 PM
  4. Kohler Rialto 3402 Bowl Water Level
    By tgeorge1 in forum Toilet Forum discussions
    Last Post: 10-01-2009, 09:50 AM
  5. Kohler 3402-PB Rialto OLD Flush Valve
    By Lindakota in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-22-2008, 12:42 PM
