Results 1 to 6 of 6
Thread: Can Shark bite fittings be used on Pex?
    Default Can Shark bite fittings be used on Pex?
    Just want to know if it is to code to use Shark bite fittings here in California
    As I understand it, they have a national approval, but local places have the final say...best to call and ask. if you go to the www.cashacme.com site, you can probably get the specs, which may be handy when talking to the inspector.
    Dec 2007
    Here is a link to the approval papers. http://www.cashacme.com/_images/pdf_...B_ASSE1061.pdf
    When used with PEX there is a plastic insert that has to go inside the PEX.
    Default thanks for the reply
    Useful posts I've checked them out and you are right...its up to the city if its ok or not
    QEST gray plastic compression fittings work well too. I don't know about codes.
    Dec 2007
    Compression fittings are not allowed in concealed locations.
