Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Triangular toilet. triangle tank Eljer
    DIY Junior Member pipehacker's Avatar
    Apr 2008
    Iowa
    Default Triangular toilet. triangle tank Eljer
    Does anyone have any thoughts, recommendations or experience concerning triangular shaped toilets and a good one to buy? Thanks.
    Dec 2005
    SW Florida
    Don't sit on the pointy end....
    Hope that helps.
    Matt
    Enjoying life in SW Florida
    Only Eljer makes toilets with a triangle tank.
    Updated 11/2/2013
    American Standard now makes the Titan Triangle toilet.
    http://www.americanstandard-us.com/a...Sheet_2586.pdf
    Dec 2007
    Seeing as there is no competition in the marketplace I recommend sitting down while getting the price. Personally I would not set up a bath for one of these.
    Plumber gizza job's Avatar
    Apr 2008
    Barrie, ontario
    Default triangle toilets
    corner toilets are great for small bathrooms and work as well as a normal one but you will probably need a flexible pan connector to get the waste away which can make the finished installation look untidy
    Its a bit black o'er Bills mothers'
    Default toilet
    What in the world would that be? the drain opening in the floor is positioned where it has to be without any "flexible pan connector".
    Rough in for a corner toilet is 12" out from both of the corner walls.
    Rough in for a standard toilet is 12" from the back wall, and at least 15" from the left wall and 15" from the right wall.
    Geologist sjsmithjr's Avatar
    Dec 2005
    Knoxville, Tennessee
    I got curious and googled it.
    "OPELLA’S MULTIFORME© wire reinforced flexible pan connector can adapt to almost any kind of situation where a toilet needs to be re-sited, without affecting the flow of waste. A unique flexible helical design offers smooth internal surface allowing rapid disposal of waste. Expands and contracts between 280 mm / 11" and 550 mm / 21.1⁄2" in length. Stays in position once bent, but can be easily repositioned if required. Suitable for 100 mm / 110 mm diameter. Can be used long or short, for bends or offsets. No adhesive required, push fit connection."
    Needless to say, plumbing is a bit different on the other side of the pond. Can you imagine trying to explain that to the AHJ?
    -Sam
    Default ?
    I would like to see how a "unique helical" design could have a "smooth interior". Then that "neck" just below the connecition point would be an interesting restriction. And the "push fit connection" would be a handyman's dream. They can hook the toilet up and then push it around the room until they find a spot where it looks good.
    Dec 2007
    I'm sure that would pass here... Like when pigs fly!
    DIY Member Wally3433's Avatar
    Mar 2010
    Illinois
    Default Titan Pro Triangle Toilet (Corner Toilet)
    I am trying to figure out if this toilet will fit my rough in.
    The diagram below has me confused though. I can understand that the rough in is 12" from finished wall to center of outlet. But what is confusing me is what appears to be offset bolt locations for the flange? There are two bolt locations shown 18.5/8 from the front of the bowl? Or are these the bolts for the seat?
    Has anyone installed a triangle toilet? Other than the obvious, is there any differences or items to note for the installation?
    http://www.build.com/mediabase/speci...heet2588v2.pdf
    The 18-5/8" measurement is for the seat.
    Rough is 12" from the corners.
    DIY Senior Member AcidWater's Avatar
    Oct 2008
    >If they stop making them, then replacements are going to be a bugger.
    You could jury rig the 5 gallon carboy from a water cooler.
    That flexible pan connector doesn't look like it would survive an encounter with the Roto Rooter man.
    DIY Junior Member girldog's Avatar
    Oct 2013
    I have a 1985 Eljer triangle tank corner sited toilet with 12" rough in. The DW line for this toilet runs at approx. a 45 degree angle to the toilet centerline. Almost every time solids are flushed this toilet backs up and overflows. Can anyone tell me what could potentially be causing this backup? This is a rural farmhouse and we don't flush anything that could plug up the septic tank so I don't think unwanted items or excessive toilet paper are to blame. I hate to have to try to replace this whole toilet due to the small size of the bathroom.
    The "Toilet bowl" itself has NOTHING to do with it being a "Triangle" toilet. IF it plugs up it is probably because you have something stuck inside the toilet and a plumber could fix it.
  1. Replies: 0
    Last Post: 08-16-2012, 07:32 PM
  2. Titan Pro Triangle Toilet (Corner Toilet)
    By Wally3433 in forum Toilet Forum discussions
    Last Post: 01-18-2012, 01:18 PM
  3. 1950's Eljer Toilet Tank Wires Question
    By Peterson in forum Toilet Forum discussions
    Last Post: 06-20-2011, 06:46 PM
  4. Tank to bowl seal for Eljer?
    By Master-of-None in forum Toilet Forum discussions
    Last Post: 09-11-2007, 06:20 AM
  5. Old Eljer Low Tank One-Piece Toilet - Water Not Filling Bowl
    By cfipp in forum Toilet Forum discussions
    Last Post: 04-21-2007, 10:44 AM
