Results 1 to 7 of 7
Thread: Crack isolation membrane?
    DIY Junior Member tate16t's Avatar
    Dec 2006
    New York
    Default Crack isolation membrane?
    Can someone recommend a crack isolation membrane. I'm doing procelain tile over a concrete slab where some cracks exist.
    Thanks in advance.
    Noble company makes some good ones. Check out www.johnbridge.com for tiling questions.
    Dec 2006
    New York
    Thanks for your response. What about a product called Ditra? I was told by a friend this is a good solution. Are you aware of this?
    I&C Engineer (mostly WWTP) Lakee911's Avatar
    Aug 2005
    Columbus, OH
    I used Ditra in my kitchen. I really liked using it. Seems a little hokey when you first start using it and putting it down, but it's worked well. It's great stuff. Pricey for what it is, but it's good.
    Jason
    Ditra is made by www.schluter.com and is a great product. It is designed for combating deflection issues, not potentially spreading that can come from a crack. Typically, crack isolation membrane is used over and to the sides of the crack by maybe a foot or so. Ditra is designed to be used in place of cbu on a wood floor, or over a slab in its entirety. On a slab, it has an additional advantage in that the channels allow the slab to breath a little, and is a great choice over a green slab (which shouldn't be tiled otherwise for at least a month). An isolation membrane is typically quite thin but elastic. Ditra is fairly rigid and much thicker than an crack isolation membrane, making its use over only a crack problematic. It is conceivable that you may want both. Ditra does have some abilty over a crack, but that is not its primary function.
    Dec 2006
    New York
    hmmm... a lot of folks must be confused about the use of Ditra because I'm being told to use it for my purpose by multiple people.
    DIY Senior Member jerome8283's Avatar
    Oct 2006
    New York
    I called Schluter and was told that Ditra can be used for my purpose. That is, to protect my tile from cracking due to potential movement of the cement floor due to existing cracks.
