Results 1 to 11 of 11
Thread: Opinions and thoughts on a PVC water main
    Default Opinions and thoughts on a PVC water main
    It comes in 10' sections and uses a PVC coupler to add to the length needed.
    Of course it is rated for potable and drinking water as confimed via the company and labeled on each pipe. I have heard good and bad things about coupling pipe underground.. Do they make a fitting to go from PVC to pex when going in the house?
    Much appreciated!
    Default Pvc
    We only use it when the size is 1 1/4" or larger, and we use 20' lengths because every coupling, or any other fitting, is a potential leak.
    Plumber jimbo's Avatar
    Best bet is to use 20' lengths with one bell end.
    PVC is widely used around here underground, and the number of problems are small. A lifted root or a rock, which damage a PVC pipe, would eventually damage copper, but the copper might hold out for a few years more!
    Feb 2005
    Talking why not just put in pex???
    why would you want to gamble with couplings
    in the ground that could potentially break from ground
    movement and shifting of the soil???
    you can buy a 100 foot coil of blue underground pex
    anywhere for just about chickenfeed..
    I have even seen peopel go to lowes and get the
    brown Zurn 3/4 pex and run that too.....
    (the experts at Lowes say it is ok to do)
    roll it down through the hole from your meter all
    the way into the home and switch it over to whatever you
    want to with a sharkbite fitting...
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Default Pvc Water Pipe
    Make Sure The Pipe Is At Least Sch. 40 Pipe
    Also You Need A Lic. Electrician To Install A New Ufer Ground Rod
    To Get Proper Electric Ground To The House
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
    Dec 2007
    MACPLUMB 777
    35 YR. MASTERPLUMBER WITH A PH.D IN WATER HEATEROLGY AND A MASTER'S DEGREE IN DRAINOLGY
    Hmmmm went back and got a Masters of Drainology now huh?
    I came up blank on a search for these degree programs...
    Where did you go India University?
    Feb 2005
    Talking Macplumb
    you can only claim you
    have a degree if and only when
    you can make ..........crap run up hill............
    Plumber Cass's Avatar
    Nov 2005
    I must have a degree then because I make it run up hill all the time with sewage ejectors and lift stations.
    Feb 2005
    Talking cant use a pump
    Quote Originally Posted by Cass View Post
    Cass you have to be able to defy the laws of gravity
    pumps are not allowed to earn a degree it has to do it on ist own
    I have seen work where
    crap actually ran up hill a foot before....
    without any help....
    If its really a water main, whats wrong with c900? Or if its a servic line how about black poly (200psi)?
    Dec 2007
    I've installed many black poly lines... nothing wrong with it!
    As far as c-900 here it would probably be installed by the water company in the street. I haven't done any 4" lines to a home yet ;-)
