Set the toilet in place without the wax ring to see if it set level without rocking. If so, you're good to go. If not, you will need to shim the low spot(s) then install. Pretty straight forward. Don't use a horned wax ring.
I am replacing some old toilets with new WaterSense toilets and I want to make sure I do the job just once and correctly.
I am looking for any tips / tricks / or gotchas for a install.
I should have a straight forward install with a 12 inch rough-in, replacing old toilets with Toto Eco Drake, good space around toilets etc.
I am not sure about levelness of floor though it does not look too far off.
House is 20 years old with PVC drains.
Any advice would be greatly appreciated.
Regards, Pippin
A penny, dime or nickel...their cheap, flat, and you don't have to go to the store for them, and they don't compress or rust. Or, you can go buy plastic tapered toilet shims, try to cut them off and hide the end and get frustrated. You don't get as much contact with the tapered ones, either...
If the flange is where it should be, on top of the finished floor, a normal wax ring is more than adequate. Don't use one with the plastic horn in it...it often causes more problems than it solves. If the flange is recessed, consider raising it with extender rings. You can use an extra thick wax ring if it is low, or two normal ones, but if you end up with too much wax, or it slips during the install, you can block a good portion of the drain; that's why you really want the flange at the right height...you minimize the wax needed, and will have fewer problems.
During the install, you should be able to feel the toilet resistance as you set it in place as you squish the wax to make the seal.
