Thread: turned around hot&cold
    Question turned around hot&cold
    so if i moved a water heater (temporary) to another space and hooked everything up then realized that i had the hot and cold water pipes swiched would it matter that much?? would it just run everything backwards?? this is just a temp move for a few days
    any advise?
    thanks nan
    Plumber Plumber2000's Avatar
    Jan 2005
    Eugene, Oregon
    If you like hot water to the toilet, hot water to ice maker if you have one, and all faucet reversed when turned on, then no it will not matter,
    Plumber for 20+years
    Default h&c
    It will have no effect on the icemaker, faucets, or anything else. You WILL run out of hot water sooner since you will just be using the lower third, or less, of the tank's hot water. Just criss/cross the connections if you used flexible connectors to install it.
    Thumbs up Thanks hj
    thanks for the helpful info hj
    nan
