Results 1 to 7 of 7
Thread: Yet another vent question....(sketch)
    DIY Junior Member SuperDaddy's Avatar
    Mar 2008
    New York
    Default Yet another vent question....(sketch)
    Just wondering if it is possible to vent a toilet in this manner (see pic).
    4" waste with a 3" vent line coming off the back of the waste line.
    I'm not sure if this is acceptable or not. I am worried about the actual "waste" getting caught on the tee portion on the "way down".
    I searched, but couldn't find anything that dealt with this scenario.
    Any thoughts?
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    Why don't you have the tee under the wall instead of the toilet and have a 90 going from under the toilet into the branch connection?
    Otherwise, if you are determined to use your current setup, you can swap out the tee for a wye fitting.
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
    Plumber BAPlumber's Avatar
    Jul 2007
    Vashon, Washington
    this is a fairly common setup for older homes. the (barrell vent) usually is used with a 2" Vent (code), I've seen it with a 3/4" vent (not code). I don't see a problem with a 3" vent, but no advantages.
    Brent
    Default vent
    You need a "Y" rather than a "T", but otherwise it is okay. Depending on the rest of the plumbing system, you may only need a 2" vent however
    Mar 2008
    New York
    Thanks for your help guys, I appreciate it.
    Hope this quick scribble helps.It shows a 4x3 toilet bend into a sanitary tee that is below your 3" vent
    Mar 2008
    New York
    Quote Originally Posted by bombjay View Post
    Excellent. Thanks. I am still tossing around ideas.
    I appreciate the help.
