Annap_mike
- Messages
- 24
- Reaction score
- 0
- Points
- 0
I have been asking questions under the possibility that I would need to remove air from one or both tanks to get thepressure in the tanks to fall below the pump cut- on point of 45psi.
What if the pressure in the tanks is such that one or both are 10psi or more below the pump- cut -in already?. i.e tanks between 30-38psi and the pump cut-on is at 45psi. Is the key getting both tanks to be between 2-5 psi less than the cut-on pressure #?
We are putting a normal pressure switch on this morning and adjusting the pressure. Not sure yet if we will add air to the tanks or adjust the switch #'s.
Thanks.
Thanks.
