Results 1 to 9 of 9
Thread: Dishwasher drain length
    DIY Member cybervex's Avatar
    Feb 2008
    Southfield, MI
    Default Dishwasher drain length
    How long can a dishwasher drain be. My dishwaser is in a peninsula and the length for the drain would be approx. 10 feet. Is this ok as long as I have the air gap.
    ________________________________
    Jay
    Mine's at least that long. Just try to keep the pipe so it doesn't have bellies so stuff can accumulate. The pumping action should keep them clean, but better safe than sorry and it can keep smells down if the thing isn't used often.
    DIY Senior Member MG's Avatar
    Jun 2005
    Illinois - Near St. Louis
    Not that it would be easy to accomplish, but it it were to be feasible for a situation like that could you route in PVC for a dishwasher drain that long so you could avoid bellies in the line?
    Note: I am a DIY'er and not a professional. My posts here are observations / opinions and may or may not be in accordance with your local ordinances.
    Default drain
    If it has an air gap, then, by definition, all the water in the hose above the bottom of the dishwasher will drain back into it, if the pump's check valve does not hold which few of them do. That being the case, it might be better to keep the hose low, i.e., below the cabinet's floor, until it gets to the sink cabinet to minimize the amount of water subject to that backflow.
    Feb 2008
    Southfield, MI
    Another option I thought of was building a half-wall at the back of the peninsula and giving the dishwasher its own drain.
    My house has no insulation or drywall yet so any idea is worth thinking about. The only drains I have left are the Kitchen sink and dishwasher.
    Jay
    Jay
    Feb 2008
    Southfield, MI
    So would you be suggesting a high loop at the dishwasher then carry the distance near the floor? That way the only water able to return to the dishwasher would from the peak of the loop.
    Jay
    Central Florida
    Quote Originally Posted by cybervex View Post
    Unless your dishwasher is a lot more expensive than mine, you might want the wall there for acoustic reasons. Make it a 6-inch wall, stuffed with fiberglass, open on the DW side to suck up the noise.
    Feb 2008
    Southfield, MI
    Quote Originally Posted by Mikey View Post
    I am hoping that this $700 Maytag will be quieter than the $100 off brand I have in my current home, which I do not find to be all that noisy.
    I was only considering the half wall to provide a place for me to give the dishwasher it's own drain. I suppose I will just build the half wall as the back of the peninsula. Better support for the granite I guess.
    Thanks for the input guys!!!
    Jay
    Central Florida
    [quote=cybervex;131025]Better support for the granite I guess.
    quote]
    Right - there's no such thing as too much support for a granite countertop.
