Results 1 to 7 of 7
Thread: Handheld & fixed shower head in same shower
    Default Handheld & fixed shower head in same shower
    My husband wants a fixed shower head in our new shower (one of those rain kind), and I want a handheld shower head (easier to clean the shower with, and when shaving, etc)
    We have a moen tub/shower valve installed, but the tub side of the valve is plugged. I want to make it where the handheld shower hose uses this outlet, and the shower head uses the regular shower outlet on top.
    What kind of attachments/fittings do I need to get to do this? Most of the handheld shower sprayers I've seen screw onto the shower arm. Is there a shower sprayer connection that goes directly into the wall?
    Sorry if this is a dumb question, but I can't find anything specificly like this. I also wouldn't mind having one that attaches to the shower arm either (shower arm that switches from handheld to fixed by turning something), but I don't know where to look for those either.
    Thanks for your help!
    -Karin
    Karin, many valves do not allow you to use both outputs. You would also want, need, a divertor to allow you to use one or the other (both is an option, but the divertors get more expensive). If you can accept both on all the time, it's easier. You'd need either a stop valve to turn off each head, or a divertor valve.
    Often what is done is to put a twin-el on the currently used output to send the water two places.
    Yes, there are fixtures to mate a hose for a hand-held in a wall mount. Not sure if Moen makes one.
    In the Trades mattbee24's Avatar
    Mar 2007
    Fremont, OH
    Alsons has a wall mount outlet that could go in place of your current diverter spout. You can check it out at there website www.alsons.com. You will have to connect some type of diverter to this so it will work for the hand held and the regular shower head. They have the diverters to do this at Alsons also. I think the outlet you are looking for is a model 4980. Check it out and see if I am on the right track.
    Matt
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Default Shower Head
    They Make A Deverter That Mounts On The Shower Arm
    That Allows You To Have A Fixed Shower Head And A Hand Held Coming Off The Side Push In For One Or Pull Out For The Other
    I Have Used It Many Times Over The Years :d
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
    Dec 2007
    This would be what you want! Alsons #4923 it comes in many finishes.
    Alson's also makes a vac breaker which would be needed to prevent dirty water from possibly siphoning into the water system, if the handheld shower head is submerged in the wastewater, and causing any contamination. The handheld showerhead hose is threaded directly onto the breaker.
    Default valve
    You cannot use one opening for the shower and the other for the handheld. First you would need some way to divert between the two, and normally that is done with a control on the spout, which you would not have. Then, the back pressure of whatever, assuming the hand held, is connected to the tub port would force water out of the shower so both would be operating at all times when using the hand held. You need a multiport diverter if you want to do it from two different wall connections, or the shower arm diverter to do it all at the shower head.
