Results 1 to 7 of 7
Thread: Tub spout leaking
    Default Tub spout leaking
    cold water is leaking from the tub spout. I removed the handles replaced the stems. Water still was leaking. Removed handles and stems again looked closer inside and there is what looks like about a 1" pipe bringing the cold water up but inside that is a smaller pipe about the width of a straw, it looks like the end of that pipe might be a little chewed up, that also would be about where the rubber end of the stem would sit up agaist. Assuming thats the prob., can I sand that smooth? thanks in advance for any help!
    Plumber krow's Avatar
    Feb 2008
    Ontario, Canada
    What you are looking at is the "seat". You can get a seat wrench or a large allan key (some seats are square openings, some are hexoganal) to remove the seat. You can usually buy a replacement seat if the faucet is not too old, or if the seat isn't too chewed up, you can file it down to a flat surface. (filing it down may make it too small)
    Default seat
    If you sand it you have to do it like grinding a telescope mirror. Stroke, rotate, stroke, rotate, etc. until it is smooth.
    Quote Originally Posted by krow View Post
    Is the seat ever round? What I see inside is round.
    Dec 2007
    This is a drawing of a seat. Actual size and shape may vary.
    There are many different shapes of seat wrenches used the one in the picture I provided actually takes a square one. It is critical that you use the right one to avoid stripping the seat and making the job much more diifficult meaning expensive...
    It is always best to install a new matching seat. In a pinch they may be sanded smooth where the washer contacts.
    DIY Senior Member Wrex's Avatar
    Mar 2008
    New Jersey
    I had this same problem with my Gerber diverter shower faucet the seat will either be square (a real pain to remove if stripped) or hexagonal (much easier to remove and less likely to strip).
    My seats needed a square remover and were badly chewed up. Not to mention really in there tight.
    After and hour of gently pounding the tool in to get it to "bite" I finally broke the dumb thing loose.
    Luckily the new seats were hexagonal and will be easier to remove in the future if need be.
    Feb 2008
    Ontario, Canada
    If you do not see a square or hexagonal in the centre, you could be looking at the longer type seats. This one is for an emco tub and shower faucet. A few other brands have similar lengths . The sqaure or hex hole is not evident in some seats, but they are there, just a little deeper
