Results 1 to 2 of 2
Thread: Shallow Well Jet Pump Venturi and Nozzle
    DIY Junior Member srmcclur's Avatar
    Jul 2011
    Vermont
    Default Shallow Well Jet Pump Venturi and Nozzle
    Hey. I have a new Dayton convertible jet pump with a shallow well bolt on ejector that I'm installing for a lake house. It's just drawing water from a hose from the lake only about 6 feet in depth and 100' of run.
    I bought the shallow well ejector set and it has a variety of venturis and nozzles. It's apparent how the venturi screws into the ejector but there really aren't any directions and I can't figure out how the nozzle installs into the pump/ejector in relation to the venturi.
    Sorry for the stupid DIY question...any help is appreciated !
    Porky Cutter,MGWC Porky's Avatar
    Jan 2008
    Virginia Beach, VA
    The venturi should screw into the bolt on jet assembly, then bolt the assembly to the pump. The 3 venturi's are for different depths vs. pressure. In your case it won't matter much. I'd use the venturi with the largest inside diameter.
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
  1. Stuck jet pump nozzle
    By Popz in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-01-2011, 01:06 PM
  2. Venturi heating system....frustrated electrician
    By scelectrician in forum Plumbing Forum Discussion & Blog
    Last Post: 01-14-2011, 08:17 AM
  3. Air Injection two tank venturi valve system HELP
    By croghanite in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-28-2010, 07:31 PM
  4. Pump on Sears shallow well pump runs too long
    By slackattack in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-27-2008, 06:12 AM
  5. Jet Pump venturi/nozzle selection
    By toolfool in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-21-2008, 07:29 PM
