Results 1 to 3 of 3
Thread: Third floor a/c
    DIY Member Squ1rrel's Avatar
    Dec 2007
    Texas
    Default Third floor a/c
    I just moved into a 3rd floor apartment, first time in this large of a building. since I have moved, I have noticed 2 problems with my A/C.
    First, it never seem to cool off the apartment. I had the thermostat set for 75 last night, as far as I know it never dropped that low...and it was about that temp outside(also raining, hence no windows open).
    Second, I get almost no air out of the bathroom register, which is a standard ceiling grill, but only has a 1" hole in the back of it. at the same time the a/c is running, I hear a loud rattling noise above my bathroom. I believe all three floors have their A/C's on the ground.
    My questions are, are either of these normal, or would I be correct in going to the management staff?
    In the Trades Bob NH's Avatar
    Oct 2005
    New Hampshire
    First thing I would do is find out if you are paying for the electricity to run the unit that is supposed to cool your apartment.
    If you are, then you should make sure that it is cooling only your own apartment and doing it effectively. Maybe you are cooling the commons spaces if someone has tapped off the system. If you have a unit dedicated to your unit maybe it has a refrigerant leak.
    A 1" hole in supplying the cooling for a bathroom seems inadequate but may be related to ventilating rather than A/C.
    If the apartment owner is responsible for maintenance then you should get with them about fixing the problem.
    Dec 2007
    Texas
    Thanks Bob. Turns out that 1" was an intake, despite air blowing out of it... On the Upside, they came out to fix the a/c BEFORE I complained, it needed to refrigerant. Still not sure what that vibrating noise in the ductwork is though, but the ac is working, so I'm not arguing in this Texas weather!
