Mikey
The folks that installed my air handler in the attic neglected to cement one elbow-pipe joint in the condensate drain, and it leaked some water that eventually found its way over our dining room.
The Behr latex undercoat and finish-coat paint loosened up from the ceiling, and I've got a small (~5" diameter) spot that sags down from the gypsum board above. The inside surface looks fine. Is there a way to inject some adhesive or something into the void and cement this sag back to the gyp board? I'd hate to strip and refinish a large area just to fix this this small spot.
