Results 1 to 6 of 6
Thread: Hot Water Heater Keeps turning off
    DIY Junior Member finesstan's Avatar
    Feb 2006
    Texas
    Default Hot Water Heater Keeps turning off
    I have a Hot Water Heater about 50-55 gals. thats giving me trouble. Everymorning for the past 3days I noticed no hotwater. I go down into my basement to check on the H.W. Heater and noticed a (Red) light flashing on the control box. I reset the heater by fliping the switch on the the control box. This normally does the trick but now the light comes on more frequently. Can anyone tell me what could be causing the promblem? Do I need the get another H.W. Heater? My unit is only 5 years old.
    Derrick
    Plumber jimbo's Avatar
    Get out your manual and find out what code is flashing. That would tell us what might be the issue. With a control panel like that, it sounds like you have either a tankless, or a power vent. There are different issues with each of these.
    perhaps you could give us your make and model, and also post a picture of the installation.
    Feb 2006
    Texas
    Default Hot Water Heater problem
    I'm posted a diagram of my Hot Water Heater. I can't remember the make and model but I can give you that later today. This is however a power vented unit. I did check my manual for any diagnotic codes for the flashing red light but there were none. The manual simply stated to check the electical wiring and components to make sure they are working properly. I'm always having to turn the unit off and on to get it started. After reseting the switch I did watch the unit go through a heating cycle and noticed the burner was flaming in and out until it finally shut off. That's when the red light started flashing again. Do you think this is something simple that can be fixed or do i need to buy a new heater? This unit is only 5yrs old. I did the proper mantainence by cleaning any dust or dibre from around the burner but this still did not fix the problem.
    Is the fan running? Is the outlet blocked? Are there any leaks in the exhaust vent? It might be the pressure sensor or the flame detector or a blockage or leak in the flue.
    Dec 2007
    This water heater is locking out for safety related reasons! I would recommend calling a plumber to troubleshoot the unit and make the needed repairs!
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Double What Redwood Posted;
    It Is Trying To Save You And Your Family From A Dangerous
    Conditions
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
  1. tankless water heater not always turning on.
    By spreve in forum Tankless Water Heater Forum
    Last Post: 01-13-2012, 02:11 PM
  2. Water turning off for brief periods
    By Talking Dreams in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-05-2010, 07:43 PM
  3. Heater not turning off
    By Kajun in forum HVAC Heating & Cooling
    Last Post: 02-10-2010, 01:40 PM
  4. Hot Water Heater Keeps turning off
    By finesstan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-05-2008, 11:10 AM
  5. Water Pump Turning On and Off
    By Jeffrey Bovee in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-11-2008, 10:31 AM
