Natural gas union on a hot water heater
rioguia
Maryland
I have to replace my Whirlpool Flame Lock water heater. I am having a little problem removing the natural gas feed to the tank. Can anyone tell me which way to turn the union to unscrew the attachment?
I need to know:
1. should I use the large wrench on the union to hold the pipe steady or am I turning it (clockwise / counter-clockwise)?
2. alternatively, am I turning to small wrench on the bottom of the union and turning there (clockwise / counter-clockwise)?
See picture
Thanks for you help in advance.
Master Plumber Mark
www.weilhammerplumbing.com
a small queston for you
I dont mean to be sarcastic here....and usually I
try to be more helpful........but
if you dont know how to take a gas union off a water heater without asking advice on a plumbing forum......
do you think it a good idea to attempt to tackle the job in the first place??
it appears from the photo that you want to crank it counter clockwise?
dont get yourself in troubles...
rioguia
Maryland
I still need help.
Are you telling me to crank the large wrench counter-clockwise?
Herk
S.E. Idaho
From what I can tell by the photo, your silver-colored wrench is in the correct position, but you may need a larger backup wrench.
And what Mark said is probably true: you're risking the life of yourself and your family as well as major property destruction if you mess up. It's not what you know about plumbing that will get you into trouble, it's what you don't know that you don't know.
Gary Swart
Yakima, WA
If you really look at a union, you can see which way the come off. I'd replace that solid plumbing with a flex pipe made for gas. Hope you know enough not get get another Whirlpool.
union
The big nut has thread on one side of it. That thread unscrews counterclockwise from the half of the union on that side. In your picture it appears that the threaded half is on the bottom.
Gary Swart
Yakima, WA
If you try to go the wrong direction, it will not move, but you won't hurt anything. I second the opinion that you don't have the experience to be messing with gas. Call a licensed professional.
Redwood
Gas...
The energy source that can make your house sneeze...
One minute you own a fine home...
and the next minute you have a vacant lot with a pile of toothpicks in it!
Seriously! Hire a plumber for the gas work!
