Results 1 to 1 of 1
Thread: Speaking of low flow
    Plumber jimbo's Avatar
    Default Speaking of low flow
    Has anyone had any experience with a couple of new products from Sloan:
    1) The retrofit "green" flush handle, which will flush 1.1 gal if you lift if up, and full 1.6 if you push it down. It is figuratively "green" but also is ACTUALLY green, and the plastic handle has antimicrobial coating. ( "Uppercut")
    2) The "smart" flushometer which times your presence. If you finish your business and walk away in under 65 seconds, you get a mini-flush. Stay longer, and when done, you will get a full 1.6 ("ECOS")
    Any particular issues with either? I can post links, but it is all on sloanvalve.com
