How to store a used pump?
riccet
Hi, just recovered a 1998 jaccuzi deep well jet pump 5RP2 (separate pump/motor) and wish to store this for future use. Should I do anything special? This could be in storage for any number of years... Not sure if I should just drop it in a bucket of oil, or should I take the pump apart and rebuild it, etc?
Any thoughts appreciated!
Speedbump
Active Member
Riverview, Fl.
I don't see where you would have to do anything special to store it.
If it's anything like the Jacuzzi Pool Pumps, the Dumpster might be a good place to store it.
bob...
Bill Arden
Computer Programmer
MN, USA
www.billarden.com
I like to pour pure mineral oil in my cast iron pumps to force the water out so they don't rust. You can buy mineral oil at the grocery store.
riccet
bob...
LOL, I guess their airplanes weren't too hot either. From what I can tell around the web, this pump is used in some high end homes.
Thank you, that sounds like a plan. I actually have some around that I use to cure wood with.
Bill Arden
Computer Programmer
MN, USA
www.billarden.com
Update:
I took one of the cast iron recirculating pumps out of storage and hooked it up.
I could not get it to push the air bubbles out of the loop, so I opened up the output and ran some water into a pail.
The water was frothy and slow for about 10 seconds and then took off and ran good.
So I am guessing that the oil was too viscus for this magnetically coupled pump.
