When a drain is designed improperly and one fixture siphons the water out of another fixtures trap, when does the siphoning happen? While the drain water is quickly flowing past the pipe or immediately following it?
RUDYTHEPLBR
EAT "WILD ALASKA SALMON" IT'S GOOD FOR YOU AND YOURS.
High flow can create a venturi vacuum, but when the water flow stops, the inertia of the final water can also create a low pressure area behind it. So you answer is either or both times can cause the problem. But those same conditions will make a drain flow faster if it does not have a vent.
