Results 1 to 6 of 6
Thread: Will this tub vent? Pic attached!
    DIY Member jpb116's Avatar
    Feb 2008
    Massachusetts
    Default Will this tub vent? Pic attached!
    Please bear in mind that the vent tube will be tied into the vent for the shower going through the roof.
    DIY Senior Member construct30's Avatar
    Jun 2007
    NorthWest PA
    That is not a proper tub hook up. The vent is connected after the trap, not before, I see no trap on your install. You need to do a bit more research on traps and vents.
    DIY Junior Member gmt's Avatar
    Nov 2006
    Pennsylvania
    It'll vent... It will vent sewer gases inside the home.
    Where is the trap below the drain? I'm sure someone here has a picture to post of the proper way (I have nothing readily available)
    Feb 2008
    Massachusetts
    Default trap...
    The trap is below the drain. This setup is above the floor, the p-trap is below the floor between the joists.
    Feb 2008
    Massachusetts
    Default position relative to the trap.
    So it's not proper to vent before the trap? That's good info, and the reason for my pic and question...
    Plumber krow's Avatar
    Feb 2008
    Ontario, Canada
    This is what your goal should be
