Iron toilet drain, no flange, 1 bolt disintgrated, other rusted on?
eva01
I removed my toilet and the concrete around it. I found one of the bolts has just turned to dust, the other one is rusted on. I believe the drain is cast iron or something else (it's black?). As you can see in the picture the one on the right is gone, and the hole expanded to the edge and now it's just a cutout.
The second picture is my upstairs neighbors toilet pipe for reference. I just don't know what I'm suppose to do to connect the new toilet.
1. From what I've been reading, there is suppose to be a flange that the bolts go into? There is no flange here, the bolts just go directly into the rim of the pipe. How do I get bolts back onto the drain?
2. Is there a flange I can get to go over the drain?
3. If I have to remove this section of pipe, how do I remove it from the stack? I'm guessing keep turning this thing counterclockwise...but I don't have a wrench that big:eek:
...From my experience with the other pipes, I know it'll be rusted.
4. If I can get it out, I'd like to replace it with cpvc, how do I connect it to the iron pipe. You can see in the second picture there's some kind of ring, not sure what it does yet.
5. Any other tips or suggestions would be great. If I do have to remove this section, I'll be extending it 2 inches because right now my rough-in is 10".
Krow
Ontario, Canada
The rim of the pipe is the flange that the toilet sits on. Just replace the bolt.
To remove any cast iron on that system, you will need a "soil pipe cutter" or snap cutter. (A large chain like contraption with a large ratchet). No hub couplings are the hardware used to join cast iron.
eva01
I'd like to avoid removing the pipe. However I can't just replace the bolt. If you look at the picture, the right bolt hole is no longer a hole, just a cutout. The left one is rusted on. Is there something I could attach on top of this? Other options?
Krow
Ontario, Canada
What is that plastic looking rim that is sitting in the centre? Is it the wax gasket horn? If it is, it can be removed and we can try and see how its attached to the top.
Some flanges come with little notches that the bolts slide into. The bolt that is there now, should come out with a slight tapping with a hanmmer. It doesn't look like its bolted down.
See if you can clean away some of the rust accumulation to give us a cleared view of this base, but it looks like a flange to me.
Krow
Ontario, Canada
That is a flange. It is chaulked with lead and okum into the cast iron hub joint. I'm extremely surprised that they did not use lead in between the CI and the flange (commonly done). If you can't make this flange work, then you are going to have to remove the flange and the 1/4 bend below it. You can join to it with a No Hub coupling
Krow
Ontario, Canada
Its going to be a real headache for you to cut this material, so here is what I proposed earlier
eva01
What is the CI?
Now that I look at it again...can I try to just put new bolts in the grooves and attach the toilet to that? These bolts have no nuts over the top, are there suppose to be some? I don't see how they are secured to the flange otherwise (except here where the rust was holding them in.
One more quick question, what height does the finished floor need to be in relation to the top of this flange? How much wiggle room do I have for this?
I really hope I can just reuse this pipe, thank you for all the help, this has been an ongoing nightmare.
Krow
Ontario, Canada
CI = cast iron
I don't see any reason why you can't reuse what you have
The new brass toilet bolts will be longer and have a flat piece that sits under the flange (as you will see when you remove the old one). A small drawing of what it looks like is attached to the picture. The nuts will come with the bolts when you purchase them, along with brass washers
Idealy, the flange will sit on the finished floor surface. You have1/4" max below and above the finished floor for wiggle room. The wax gasket will take up any slack between the WC and flange
eva01
Awesome! You're a life saver. I had someone tell me today on another board I am SOL and I have to replace it. I'm off to get this done, this is the only throne in my condo=)
Gary Swart
Yakima, WA
I'm sure it is possible to make this work, but I think you should consider the overall condition of what you are working with. Do you think this will last 20, 30 or more years? The condition will certainly not get better as time passes and sooner or later you will be forced to rip up the floor and replace this mess. Don't you think the time to do it right is now while everything is already torn up and open. This would be a very easy and simple job for a plumber. He would cut the cast iron pipe to get rid of all the rusted parts, use a no hub connector to transition to PVC, and a new flange. This is a doable DIY job, but I infer from your questions that you are not familiar with this type of plumbing so that's why I suggest professional help on this job.
Gary Swart
Yakima, WA
Like the old Fram oil filter commercial, "Pay me now or pay me later." Granted, it won't be inexpensive to hire a professional, but it will be far less than what you will be faced with in the future when that pile of rust finally fails completely and you have to tear out your floor.
It isn't that big a deal to remove the flange. Since it looks like a 4" pipe, you could get a new flange that uses a compression ring and gasket to seal a new one on from the inside. You could get your finished floor done, then insert the new flange, expand the fitting to make the seal, then screw it through into the subflooring. Unfortuneatly, there isn't any there! to screw into.
In the interim, you should be able to anchor a toilet in place temporarilly until you get closer to having the finished flooring down.
Keep in mind that if you are going to add tile, you need at least 1/2" of plywood then cbu or a membrane on top of the planks before you can put down the tile. If your plans are along that path, your flange will be too low.
They do make flange repair rings that would give you a place to anchor the toilet. They are designed to use the screw holes and then anchor to the floor, but again, they cut the boards such there there doesn't appear to be anything to screw into. They also do make flange extenders, but the state of the flange you have means I'd really prefer to replace it.
If you whack the edge of the flange, it will likely break, then you can pry off the lead that is holding it in place. Or, if you're too timid to do that, you can drill out some of the lead, pry it out, then pry off the flange.
It sounds like you may be installing and removing the toilet as you do your remodeling...wax rings are cheap, but depending on how often you are going to do it, consider a waxless seal. You'll have to wire brush some of the crud off the inside of the pipe to allow a good seal first, though.
flange
I would do it the easiest way. A couple of whacks with a hammer and chisel and the old flange would be off. Another whack and the lead and oakum would be history. Next, replace the floor and flooring leaving a space around the closet bend's riser. Finally, I would come back and lead/oakum a new flange onto the pipe. No messing with the existing pipe, or cutting it, no PVC or ABS transitions, and no leaks.
eva01
Ok, after reading the replies and cleaning more gunk off I see what you mean. I originally thought the pipe/flange was one piece, sure looked like it. Now I see the top and outside ring are around the pipe. So the pipe itself doesn't have a lip at the top?
I'll try to whack the flange off tomorrow, or else I'll be getting a knock from my neighbors:D
I think I know what to buy, as I was just at HD. The cast iron flange replacement, it's pvc on top and it has 3 screws inside that expand the elastic hub right?
Or do I need to just put a new cast iron flange on with oakum and lead? What does that seal exactly, do I solder it...totally lost once again.
Krow
Ontario, Canada
To do the oakum and lead joint, you will need about 1/2 pound of lead, I metal pot to melt the lrad in , 1 ladle(for pouring the lead), 1 burner to melt the lead, at least 1 chaulking iron to pack the oakum and some oakum (Horse hair).......... oh, I almost forgot, a few years of experience in the old school plumbing
I suspect you are not equipped to do this. You may want to stick with rubber seals
Cass
Be sure you have everything you need and the knowlage to do it, B 4 you wack anything off.
SRdenny
Plumbing Contractor
SF Peninsula
I'd do what hj suggests. In fact, I did one yesterday. I still lead my ring in. Haven't purchased lead but once in over 30 years. Lead=the recyclable metal.
Master Plumber Mark
www.weilhammerplumbing.com
I agree with cass
I agree with Cass,
Never Wack anything off unless you know what you are doing..
and are willing to accept the consequences for your actions....
