Many toilets will work that way, but it is not by design, it is a side effect. If you want reliable flush, push the lever down fully. You should release immediately. A partial flush is not reliable - it is an acquired feat that requires a little finnese - it is not a designed feature. Those who espouse it as a planned feature are somewhat mislead...
Those toilets that are designed for it send fairly precise, measured, and tested quantities of water in their selected modes...on one not designed for it, it's a crapshoot and may require a second flush which defeats the purpose as it would probably use more water than if you did it 'right' the first time.
