Results 1 to 7 of 7
Thread: Sprinkler zone wouldn't stop
    Engineer maddog's Avatar
    Aug 2006
    near San Jose, CA.
    Default Sprinkler zone wouldn't stop
    Have a timer with 5 zones active. One of the zones would not stop this morning. Tried to stop sprinklers manually by turning off the timer, but water would not shut off. Had to turn off water to irrigation system to stop the sprinkler. Is this most likely a problem with the anti-siphon valve getting stuck open? Or a problem with the timer? Sorry for the lack of details. Thanks much for your help.
    Aug 2006
    near San Jose, CA.
    I'm thinking it's the anti-siphon valve. Came home and unplugged timer - turned on water and the sprinklers came on again. The solenoid looks a bit corroded and probably has dirt or something inside. Will replace and see what happens.
    DIY Senior Member Wet_Boots's Avatar
    Mar 2007
    Metro NYC
    Unplug a timer to be certain it isn't the problem.
    Default valve
    IT is inside the valve. Something is torn, broken, or stuck inside the valve.
    Rancher
    Guest
    The valve operates by that solenoid opening a bypass orifice, which causes the main valve to spring open. If you get a grain of sand in the solenoid-orifice seat, the valve will not turn off.
    Solution, unscrew the solenoid, clean it out.
    Rancher
    Aug 2006
    near San Jose, CA.
    Great - thanks much ... will give it a try.
    Aug 2006
    near San Jose, CA.
    Unfortunately, removing/cleaning the solenoid didn't do it. A replacement solenoid at HD was almost as much as a new valve, so I replaced the valve - and I'm back in business. Thanks much for the input. -dog
