Results 1 to 11 of 11
Thread: 2-12gauge and a 14 gauge for ground?
    Default 2-12gauge and a 14 gauge for ground?
    Is it okay for me to use two 12 gauge (for hot and neutral) and one 14 gauge wire for ground? I think 14 gauge is easier to work with but I don't want to violate code.
    I'm installing a dedicated circuit running EMT for a gas dryer.
    Thanks.
    Jun 2007
    North Carolina
    Quote Originally Posted by trackerxx View Post
    Thanks.
    Wouldn't the EMT be the ground?
    If you install a wire for the equipment grounding conductor it MUST be a #12
    I&C Engineer (mostly WWTP) Lakee911's Avatar
    Aug 2005
    Columbus, OH
    No can do.
    Jason
    DIY Member MarkHash's Avatar
    Mar 2007
    Wisconsin
    I am sure it's against the code, but it would definitely carry the fault current long enough to pop the breaker, which is what it is there for. I'm sure there are deep reasons for like sized ground wires but it escapes me right now. Probably to make sure the circuit breaker operates properly in much larger applications.
    I don't know code, but I would use 12/3 color coded for 220VAC. (Red, Black, and Green) Of course electricity doesn't care what color the wire is, but if it had to be worked on in the future, it might help.
    Jun 2007
    NY State, USA
    For a GAS dryer?
    Electrician Chris75's Avatar
    Aug 2007
    Litchfield, CT
    Quote Originally Posted by Speedy Petey View Post
    For a GAS dryer?
    And I thought the 12 was a bit much... (I know its required....)
    Aug 2005
    Columbus, OH
    12/3 is ROMEX® and it contains a white, black, red and a bare ground. It's 4W, which most new dryers should be. For a 220VAC dryer this COULD be used, but generally they're at least 30A so a 10/3 would be used for the increased amperage. He also said that he's running EMT, so ROMEX® probably isn't the right choice. Lastly, a gas dryer is probably 120VAC.
    Aug 2005
    Columbus, OH
    Actually, I was thinking that he could supply a 15A breaker and then get away with it, but the more that I think about it, if you increase the current carrying conductor (say for voltage drop, for example), I'm pretty sure the ground needs increased too. The EMT could be used if its continous and contains any appropriate bonding jumpers.
    Aug 2007
    Litchfield, CT
    Quote Originally Posted by Lakee911 View Post
    210.11(C)(2) requires a 20 amp laundry circuit.
    Jun 2007
    NY State, USA
    THAT was my point!
