Results 1 to 4 of 4
Thread: Which Thermostat
    DIY Member cybervex's Avatar
    Feb 2008
    Southfield, MI
    Default Which Thermostat
    Which White-Rodgers or Honeywell thermostat should I use for a GMH95045BX? I would like the a touchscreen model.
    I am unsure which model to buy.
    My big question would be: Do I need a single or multiple stage thermostat?
    Thanks in advance
    ________________________________
    Jay
    I am headed out....no time to research right now, but I am thinking your furnace is variable speed blower, 2 stage burner???? Honeywell and White Rogers both have excellent websites and tech support. Also, your Goodman installer has access to excellent Goodman tech support, who can recommend a compatible t-stat.
    Will try to post more info later if I have time.
    I have used the Honeywell VisionPRO 8000, both at work and at home for over a year now. Nothing bad to report. Would highly recommend.
    Feb 2008
    Southfield, MI
    Well I guess I only need a single stage thermostat. The spec sheet says:
    Dual$aver
    This furnace is capable of the following heating modes:
    Single Stage (Factory Setting)
    Modifi ed Two-Stage
    Fixed 5-Min Low Stage
    Auto Time (1-12 Min) Low Stage
    To change from the factory single-stage operation, adjust the
    dipswitches on the ignition control as follows:
    Note: This furnace is designed to be used with a single-stage room
    thermostat.
    Guess I will go with the White-Rodgers ---I like the blue
    Jay
