Removing Water Softener - capping connections
bobwood
We've moved to city water and have removed our Water Softener. I now have two open pipes (input and output) with a sliding shutoff valve. The sliding plastic bypass/shutoff value leaks slightly. I'm looking for a quick solution that does not involve cutting and soldering. Is their such a thing as a male end cap to plug the lines? Picture is attached. Thanks in advance for any help!
bobwood
I've got a tubing cutter but am crappy at soldering (I've done it a handful of times but need more practice). I've been using compression fittings for some recent work and saw the SharkBite stuff but did not know how it worked. Thanks!
Gary Slusser
That's all folks!
You should check the water company's web site for their water quality report and find out how much hardness they have, and reinstall the softener if there is more than 3-4 gpg of hardness in your water.
That by pass valve is repairable. It is probably a Taras, I think that's the name of the manufacturer, and the 4 orings cost next to nothing. One end knob unscrews from the shaft that has the orings on it
