I have a submersible pump with a galvanized tank that keeps getting water logged. If i take the plug out of the top of the tank and drain it, it operates normally for about a week and then starts short cycling again. I can't find any leaks and I am sealing the plug in the top well when re-installing. There is a shraeder valve in the float valve fitting if that means anything. The tank is inside and in excellent condition. No rust.
Any suggestions? Draining the tank is a royal pain and i am worried about my pump motor.
Thanks,
Dave
Thanks,
Dave
