Results 1 to 7 of 7
Thread: Wiring a 6-20R Plug
    Default Wiring a 6-20R Plug
    I am running a circuit for a tanning bed requiring a 220v 20amp dedicated circuit.
    I understand the red and black go on the gold connectors, but what goes on the green one? is that for a ground or neutral?
    Electrician Chris75's Avatar
    Aug 2007
    Litchfield, CT
    Quote Originally Posted by skid2964 View Post
    green is always Ground... If your wiring a 6-20r plug why are you even asking?
    Quote Originally Posted by Chris75 View Post
    So the neutral is not used at all?
    I'm just making sure, that's all.
    Licensed Electrical Contractor Speedy Petey's Avatar
    Jun 2007
    NY State, USA
    NO. There is NO neutral in a straight 240v circuit.
    Computer Programmer Bill Arden's Avatar
    Sep 2006
    MN, USA
    You would have to use a L14-20 if you need a neutral wire.
    But like others have said... "there is NO neutral in a straight 240v circuit."
    Important note Ė I donít know man made laws, just laws of physics
    Disclaimer: I'm a big fan of Darwin awards.
    Default circuit
    A 220/240 circuit would not need the neutral UNLESS it has a 110/120volt control circuit, which is a possibility if it is digital.
    All the responses jarred my memory. it's been a long time since I wired a 220v circuit.
    I remembered: I've wired these cicuits with all four wires! now I have an option for only three! But I remember now, they were circuits for ovens and dryers, etc. which needed the neutral to make an 125v control circuit.
    It is elelmentary, I know, but I just wanted to make sure.
    Thanks for the responses. I have the tanning bed up and running fine, my wife is happy now.
