JackStephan2000
- Messages
- 12
- Reaction score
- 0
- Points
- 0
The packing nuts on the stops are probably a little loose and need a quarter turn to stop the leak.
You should be able to turn these slot headed screws in as far as they will go (don't over tighten) to shut off your faucet.
It hasn't been asked yet, but I need to know if the centre valve is only a thermostatic control or an "on / off" . Some units are only to control the temperature and not the on/off. Do you know what model it is? This will tell me what the botton with the spring is.
I will try to get you the model number later if it's written on it or from my records. The valve has two dials, ON/OFF on top and temperature on the bottom.
