analogguy
Help. The shower valves (both hot and cold) have developed slow drips. The brand is Kohler and is probably at least 20 years old. I unscrewed the retaining screw and pulled the handle off. As best as I can explain it, this is what I found. The valve is threaded into a flange which sits proud of the tile. The trouble is that the valve is set in about 1/4" and does not have a conventional hex shape to loosen. Instead there are 2 flat spots on either side. I have tried making a crude tool to loosen it but have not been successful so far. I got a small section of 1" copper pipe and cut it so I ended up with 2 teeth on it on one end. I then drilled a hole toward the other end so I could put a screwdriver through it to get some leverage. Snapped the screwdriver in half and actually deformed the other end. I know that there must be a tool for fixtures like this, but what is it called? If not, what else can I use? Thanks.
