Results 1 to 6 of 6
Thread: Solar Flat Plate draindown system
    Rancher
    Guest
    Default Solar Flat Plate draindown system
    What's that thingie at the highest point on a flat plate solar hot water system, that lets the air/steam out but closes when the water hits it.
    Is it the same as a watts air vent that's used on an air scoop?
    Rancher
    Sep 2006
    MN, USA
    Spyrovent?
    rancher,
    in a word YES. Its not the same thing as a spirovent however. Its just a vent with a float.
    Lou
    Rancher
    Guest
    BigLou,
    Thanks, do you have a source?
    I'm putting mine back on the roof after a 80 mph windstorm, just used a check valve before, thought I'd do it right.
    Rancher
    Rancher,
    here is a link of what you want. I get all my stuff at the local supply house, make sure that any air on both the supply and return lines can get out
    http://www.taco-hvac.com/en/products...nt_category=87
    Lou
    Rancher
    Guest
    The Hy-vent is exactly what I have avaiable to use except it is the Watts brand.
    But I don't know how it operates, I understand there is a float inside that closes it off when the air is fully purged, and it kinda makes sense that it re-opens when the water drops.
    I want this for freeze protection, i.e. drain down at night.
    Rancher
