Results 1 to 9 of 9
Thread: Power disconnect panel for spa...
    DIY Junior Member MJ32V's Avatar
    Feb 2008
    NY
    Default NEC min height req'mts for spa power disconnect?
    Hi All,
    What's the height requirement for a power disconnect panel for a spa? Outdoor location 50' from side of residential 1 family home. Disconnect will be mounted on 4x4 press. treated post just shy of 10' from closest point of spa. 220V / 50A GFCI.
    MJ
    6' 7" max.....but don't mount it that high.
    Feb 2008
    NY
    6' 7" max... ok. What's the minimum height above ground?
    While we're on the subject, what's the recommended height?
    MJ
    High enough so it doesn't sit below normal snow depth or standing water. You don't want to have to crawl on the ground to remove and replace. My unprofessional opinion...
    Electrician Chris75's Avatar
    Aug 2007
    Litchfield, CT
    I agree, put it so you work on it like a gentleman...
    Feb 2008
    NY
    jadnashua -
    There's never more than 3' of snow in the area the disconnect is located. Let's say that I placed panel 4' off ground, then later find out that code has a 5' minimum height, then I have to re-work things (arghh!). So to avoid issues later, I need to know what the code minimum height requirements are.
    MJ
    Jun 2007
    North Carolina
    Quote Originally Posted by MJ32V View Post
    MJ
    There is no minimum height just a maximum of 6 feet 7 inches to the center of the grip.
    Feb 2008
    NY
    Great. Thanks....
    MJ
    If your spa is ever used by kids, I would suggest placing the disconnect low enough to be easily used by the youngest---if Mom gets her hair caught in the suction port, help might need to come from the smallest of spa mates.
    For a scary (and tragic, but relevant) story see
    http://www.poolspanews.com/2003/102/102entrapment.html
    /Kop
    [In God we trust. All others, bring data ... ]
