Results 1 to 6 of 6
Thread: double check valve same as backwater valve ?
    Default double check valve same as backwater valve ?
    I just spoke to a plumbing company to install a BWV and she said you mean a backflow valve or a doublecheck valve.... I told her it goes on the sewer line, she said the doublecheck valve is also the same thing.
    I am not sure they are the same thing- the double check valves seem to be on the supply lines to prevent some kind of cross contamination. This is getting complicaated VERY fast!
    Dec 2007
    You are correct... It is the office help that doesn't know!
    It makes it really hard to follow your whole problem when you start a new thread with each question...same problem...keep it in the same thread. The history of what was asked and answered will also help keep things on track.
    Default Will do- different forums have different rules
    if it is a seperate question- inspite of it beingl the same problem, but a seperate concept, they tend to wnat to see it in a different thread.
    But I will just post to the original thread from now on.
    How long have you been here? It shows you've made 16 posts.
    It's not a big deal, but you are trying to solve a single problem...seeing the progress of ideas is MUCH easier if it doesn't bounce all over the place...otherwise, there is absolutely no connection that is useful later on. Search would find the though, regardless of where it is in the thread.
    Default thread
    Who is going to take the time to do a search for a previous question. A check valve by definition is a restriction in the sewer's flow, and if you use two or more it compounds the problem. She did not know what you were talking about and was thinking about a water supply anticontamination valve.
