Ever hear of Technopure
sisu
Need a filter system
I'm in need of a new filter system. Looked at the Technopure system at the
Boston home show 3-1-08. I like the idea of no salt one less monthly gotta do project .I hope Eric responds and clears up any uncertainty.It sounds like a system for the 2000's after all everything else is advancing.
My water analisys
Iron 6.00 mg/l
Manganese 0.173 mg/l
ph 6.49 units
turbidity 17.58 ntu
:confused:
Bob NH
New Hampshire
I'm in need of a new filter system. Looked at the Technopure system at the Boston home show 3-1-08. I like the idea of no salt one less monthly gotta do project .I hope Eric responds and clears up any uncertainty.It sounds like a system for the 2000's after all everything else is advancing.
My water analisys
Iron 6.00 mg/l
ph 6.49 units
turbidity 17.58 ntu
:confused:
The iron, manganese, and turbidity of your water are all in the range of "very bad". The pH is so low that it will corrode your plumbing and risk causing excessive copper contamination of your water. I am trying to get information on the Technopure system but I doubt that it will solve those problems.
http://www.epa.gov/safewater/consumer/2ndstandards.html
Speedbump
Active Member
Riverview, Fl.
I seriously doubt it too. What do they claim this Technopure system will do. Do they tout it as a water softener also?
bob...
Alternety
Like an engineer
Washington
Bob, you might want to read their site to get the flavor of the site. As an example, their have an arsenic removal system has two tanks (Brim and carbon) with one of their devices on each side of the two tanks. Cost $6K. Look under well water home system.
Incidentally my Hmmmmm above was for the sudden absence of the sales rep.
Speedbump
Active Member
Riverview, Fl.
I'll take a look at it tomorrow at work. That mention of no salt is starting to sound very familiar.
The no salt softener has been around for some time too. Don't quote me on the spelling but instead of salt, you use Potassium Chloride I believe it is. More expensive does less than salt, but it's not exactly salt is it?
bob...
Alternety
Like an engineer
Washington
There are products for pools (which is my primary interest for this thing) that take a similar approach. They generate silver ions and they generate chlorine in the device to provide oxidation of bad organics. These require that you make the pool water salty. The salt is the chlorine source. I believe they reduce the chlorine before it leaves their device (I think, don't quote me) so the pool does not smell of chlorine. The other side of this is that to keep clear water, the entire contents of the pool must pass through the filter in some period of time. This implies more pumping time that needed for a system with a residual oxidizer such as chlorine or bromine. These devices tend to be rather pricey as well.
Jdoll42
Computer Systems Engineer
In Illinois near St. Louis, MO
From a chemistry point of view, "table salt" is sodium chloride. If you drop to the next period in group 1 of the periodic table (below sodium), you are at potassium. By itself, potassium tends to be a bit more reactive than sodium, but will bond with chlorine in much the same way as sodium. Long story short: potassium chloride is a salt.
Now can you go to the "big box" store and buy it off the shelf? Doubt it. My guess is it's not the easiest thing in the world to find.
sisu
techonopure
O my where is Eric when you need him :mad:
Will it be the same after the sale :confused:
Speedbump
Active Member
Riverview, Fl.
Their units are re-beddable but softeners are not? Where did they come up with this.
My next question is how do they claim to be softening the water? As near as I can tell, all they are doing is removing iron and manganize and odor.
bob...
R
Rancher
Guest
I think we scared Eric off.
Oh well, another snake-oil saleman down and out.
Rancher
Gary Slusser
That's all folks!
My water analisys
Iron 6.00 mg/l
ph 6.49 units
turbidity 17.58 ntu
:confused:
That equipment is not going to remove 6 ppm of iron. Neither will a softener. You will need an iron filter or some other type of treatment, and that might be part of the additional 'stuff' included with their ionizer but.... I've seen ionizers used on pools and they work very well but I've never seen one used one 'potable' water.
The acceptable EPA range for pH is 6.5 to 8.5 but anything below 7.0 is acidic. You may or may not want to buffer your acid but your water is acidic enough to corrode metals.
You don't mention the hardness in your water.
You can use regular water treatment and spend thousands less than the Technopure.
Bob NH
New Hampshire
Hello everyone,
Bob NH, we would be more then happy to talk with you. Please get me your contact information and I will get one of the more tech savvy members to get in touch with you as I don't speak "engineer" fluently. We would love to work with you on this testing so please get back to me.
Regards,
Eric Halnon
TechnoPure
No technical person from TechnoPure has contacted me since I replied by PM on February 28.
Alternety
Like an engineer
Washington
I have been trying to see if they are part of another company or what they have at their address. So far it looks like the address on their web site is an office building. There are a couple other, aparantly unrelated, companies listed. Curiously, not them. YMMV in searching.
It does rather feel like they were scared off. Not even an "I am gathering the information you have asked for, or buzz off we are doing fine without you, or I am busy and I will get back to you".
Dunbar Plumbing
www.KoldBreeze.com
The Yahoo! Slurp spiders, google spiders along with msn and Ask Jeeves spiders
are on this site like white on rice when it comes to content.
Sooooo....what will happen indirectly is that these searches will embed themselves directly into keyword searches on this product, the tag lines along with the content of the body of this thread will be in plain view for all to see that his time here was detrimental and not uplifting to make a silk purse out of a sow's ear.
I see nothing clamped or installed into a potable water system that can effectively treat water given the flow rates of when the plumbing is used.
What sucks is that people are sold this stuff, it becomes a mental move more than a realistic or factual move.
Meaning the placebo effect when you give 12 people medicine and some of them were given non-medicine medication to see if they "thought" they felt better.
Very telling how the mind can sense improvement when there really is none...
Alternety
Like an engineer
Washington
The thing about mind is silly. I KNOW my car runs better after I change oil and wax it.
