mrspaceman
My house has low water pressure and I was hoping to get some help either diagnosising the problem or coming up with a fix. Here are the details.
Our well is in a pit beside the house. The well has a deep-well jet pump that (my guess) is about 8 years old. The problem first became apparent because the pump was running all the time (should have seen the electric bill). I did the following:
Checked the water inlet to the pressure cutoff switch, which was clear.
Checked the pressure cut off switch itself, it was fine. I had replaced it a couple of years before and it still looked fine and it worked fine when I manually actuated it.
Checked the pressure in the well tank (with the tank empty) and it was as expected about 2 pounds below cut-off, or 28 pounds of air pressure on the 30-50 PSI pressure switch.
At this point, I felt like I could either replace the switch w/ a 20-40, but didn't want that low pressure.
I then adjusted the internal screws so that the pump cycles. It now cycles between ~25 and 35 psi. Readjusted the air pressure, so everything is fine, except the water pressure stinks. So I'm left with a couple of questions:
Why the original drop in pressure? Pump used to cycle just fine at 30-50.
Another odd thing, unrelated but annoying is that most of the house has ok (though low) flow, the kitchen has annoyingly low flow. The kitchen and the external spigot outside the kitchen were part of an addition and are furthest away from the well. This has always been this way and is real annoying with the pressure drop. Ideas?
Is there anything that I can do to boost the pressure? In internet searches, I've seen these "Pressure Booster Systems" (Torrium, Davey), basically a booster pump that you put on the outlet of your well pump. Are these any good? Replace the well pump w/ another jet? Replace the well pump w/ a submersible? Like the booster pump idea, because I hate messing with a well that gives water just fine and it seems the least expensive of the options.
Anyway, if folks want to weigh in on other things to try and/or whether anyone has had good experience with a booster and if so, which brand, I would appreciate it. Thanks!
